54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Beam system, cant offset?
Mon, Jan 26, 2009 at 10:44:43 AM | Beam system, cant offset?
Culleton
Hello,
ive just started using revit last week so very very new to this and well i've made a beam system but cant seem to change the "start level offset/ End level offset" as it seems to be grayed out in element properties, is there a way to get around this or will i have to do it the slow way and do every beam on its own? as i would like to lower the beams by -183 but cant seem to chane it.
will post screenshot if this makes sense Puh also im using Revit structure 2009, not sure if that matters?
thanks for any help/tips! Smile
Tom.
Mon, Jan 26, 2009 at 10:46:49 AM | Beam system, cant offset?
Culleton
will post screenshot if this doesn't makes sense***
Mon, Jan 26, 2009 at 10:47:21 AM | Beam system, cant offset?
Culleton
Fri, Feb 13, 2009 at 8:16:04 AM | Beam system, cant offset?
JACMD
try just checking the 3D box. if it doesn't do what you want then you have to unpin every beam/joist and change it to the elevation you want. if you pin them again i believe it wiil go back to the previous elevation.
waht i've done is unpin them and rigth click and click on detach from plane and that has worked for me.
hope this helps
First beam offset in beam system
Mon, Aug 23, 2010 at 12:24:14 PM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:21 PM
Structure Beam System Wishlist
Thu, Feb 28, 2013 at 4:18:12 PM
Beam System Tags
Wed, Feb 27, 2013 at 12:55:28 AM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:11 PM
Page generation time: 0.5087
