54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Visibilty issue
![4 Stars: 1 Votes](/images/stars_4.gif) |
im not having any luck trying to cut a wall sweep whit a window element, when i add a window to the wall the wall opens but the sweep stays as it is, i already check the opening box on the family and also creating a open ing on the project but no luck , what could be wrong?..... can a sweep be cut whit an opening ?.......
hope anyine can give a solution ... thank you
g_gualajara
Is the sweep part of the wall settings or just a hosted wall sweep?
What version of revit are you using?
If its part of the wall and in version 8, check that in the wall properties you have set the sweep to be cuttable.
If it still doesn't work, edit the window family in place, change a value in the family types then reload back into the project (you don't actually need to make any changes) this causes revit to use the new functionality of windows (revit tries to preserve previous behaviour in upgraded files until you reload them).
This should now cut. We use this all the time for block sills.
HTH.
im using revit 7.1.....
what can i do in this case?......
There is no 7.1.
This issue was fixed in one of the later builds of version 7.0. Either try to get hold of the latest build and do what i previously suggested or you'll need to upgrade to 8.0 to take advantage of this new functionality.
sweep visibilty |
Wed, Nov 18, 2009 at 12:51:27 PM
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:08 PM
Visibilty Graphics Greyed Out |
Fri, Nov 22, 2013 at 10:42:50 AM
edges color and linetype |
Wed, Apr 20, 2005 at 6:34:22 PM
Structural beam system visibilty |
Mon, Jan 28, 2008 at 6:08:26 PM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
