84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> locking detail line to ceiling for elevation view.
Fri, Jan 23, 2009 at 4:00:43 PM | locking detail line to ceiling for elevation view.
rquist
image shows sample walls and ceilng.
I hid wall to draw a "detail line" dashed line to represent the ceiling in an elevation view so when I restore the wall visibility you can see the hidden line that represents the ceiling.
I aligned and locked the detail line to the corresponding ceiling view thinking that the detail line would follow the ceiling pitch as I changed it from a 6/12 to a 3/12 and vice versa.
When I change the ceiling pitch I get a -restraints not satisfied error- which forces the alignment to unlock resulting in the detail line not moving while the ceiling assumes the new pitch.  I then have to realign the detail line to the ceiling.
I know this process works for roof overhangs.
Should it also work for ceiling planes??
Locking columns to a detail line
Fri, May 25, 2007 at 12:12:14 PM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:18 PM
Ref Level model lines in Ceiling based family
Thu, Apr 23, 2009 at 10:01:50 AM
Lines in Ceiling Plans
Wed, Oct 24, 2007 at 4:44:58 PM
How do I change the view line on the Elevation?
Sat, Jun 14, 2014 at 9:43:46 AM
Page generation time: 2.7855
