60 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Structural Failure
Thu, Jan 22, 2009 at 10:43:50 PM | Structural Failure
ajpauls
2 Stars: 1 Votes
Hello everyone,
I am fairly new to Revit Strucutre and am doing a semester long project on structural failures.... I was wondering if you could build a strucutre and essentially animate it to show it failing?
Any help would be greatly appreciated.
Thanks a lot!
Fri, Jan 23, 2009 at 9:05:43 AM | Structural Failure
4 Stars: 203 Votes
I'm not working with Struct. but I don't think so, not with Revit....
Fri, Jan 23, 2009 at 10:36:35 AM | Structural Failure
tazman1
tazman1 Avatar
You willl probably have to do several screen shoots, saved as jpg's and inserted into movie maker.  But maybe that's too much.
Tue, Jan 27, 2009 at 12:29:00 PM | Structural Failure
emgeeo
3.5 Stars: 7 Votes
It sounds like it might be too complex for Revit.  It seems like an animation program would work best for this.
Tue, Feb 17, 2009 at 2:32:03 PM | Structural Failure
MPV1
MPV1 Avatar
You can make video walkthroughs of your model but I am pretty sure you cannot animate specific elements in the model to move in an automated path or manner.
A sequence of screen-shots would be as close as you could get but it would probably be as intensive as stop-animation /clay-mation stuff i.e. not worth, doable though... Good luck on the project
Mon, Feb 23, 2009 at 7:45:01 AM | Structural Failure
FJ22
I think if this was possible, no structure failures would ever happen again...
Mon, Feb 23, 2009 at 11:31:37 AM | Structural Failure
broncos4life
3.5 Stars: 11 Votes
I would recomend using Revit to model your structure and then export to Navisworks.  Navisworks will alow you to animate your building to animate it failing...if its a connection failure.  If a beam or a column go plastic Im not sure what you could do to animate that.
program failure
Wed, Jul 4, 2018 at 3:03:38 PM
unexplained failure of dormer walls to join at corner
Mon, Feb 23, 2009 at 7:22:32 AM
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:40 PM
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:35 AM
Shading Structural Walls
Mon, Nov 21, 2011 at 11:21:47 AM
Page generation time: 0.3043
