65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
Thu, Jan 22, 2009 at 10:28:09 PM | LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
Sagir
REVIT ARCHITECTURE 2009
Hi everyone, I have been using a Macbook pro for the last month and a half and Revit seems to have some problems after running for a while, after I registered the activation code for the first time everything worked just great but now I have to ask for an activation code pretty often. When I called Autodesk to find out how I could solve the problem they told me that the best thing to do would be post the question in a forum such as this one or mac users to see if someone could share the solution to this problem.
Has anybody encountered the same problem? is there a solution to this? would you be willing to share it?
Thanks
SAGIR
Fri, Jan 23, 2009 at 4:06:49 AM | LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
samov
Apple does not support a feature the Autodesk needs to run it's license manager.
Tell apple to add the feature, it is in their bios and it is one of the main reasons why XP for example can't boot without Bootcam in intel macs.
Fri, Jan 23, 2009 at 11:18:01 PM | LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
Sagir
do you think they can add it by simpply asking them to do so? or is this one of those features they add based on demand?
thanks
SAGIR
Thu, Feb 19, 2009 at 11:40:08 PM | LICENSE PROBLEMS USING REVIT IN A MACBOOK PRO
ashevilleARCH
i had the same problem for a while, then i ditched parallels and my problem went away.  i did have to reregister once after removing parallels.
registration problems on macbook pro
Fri, Jan 23, 2009 at 11:14:27 PM
Revit architecture on Macbook pro i7 with flashdrive7??
Wed, Oct 19, 2011 at 5:11:23 PM
Using Revit with MacBook Pro 15" & Parallels [ 1 2 ]
Sat, Sep 19, 2015 at 8:06:26 PM
19
Revit architecture for Macbook pro? [ 1 2 3 ]
Thu, Oct 27, 2011 at 7:25:36 AM
39
Display weirdness using Macbook Pro with exterior monitor
Fri, Nov 14, 2014 at 11:39:26 PM
Page generation time: 1.6342
