118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Panel selection in curtain walls
Thu, Jan 22, 2009 at 8:27:35 PM | Panel selection in curtain walls
renatolemus
Hi. I've been going insane trying to figure out how to select a panel in a curtain wall and change it to a solid brick wall in revit architecture 2009.
I've been reading almost every topic here about it, and all say the same thing but it's not working for me:
I create a wall specifying in the type selector as a "curtain wall", I have modified the family type to create a wall made of 4x4 solid panels. ok, everything is fine at this point. Then I click in the curtain wall, hit the tab key many times to highlight the panel until a text appears saying "curtain panel:system panel:solid", then I click on it, it turns red, and when I go to change the type of panel in the type selector drop down list, is greyed out!
 am I missing something?, I hope someone can help me. Thanks in advance.
Thu, Jan 22, 2009 at 8:40:31 PM | Panel selection in curtain walls
timbo89
timbo89 Avatar
4 Stars: 5 Votes
When you select the panel, a "pin" showed up (the blue thing at the end of the line connected to the panel). This means it's locked so you can't modify it. Click on the pin to unlock it (a red line will go through it when it's unlocked) and then you'll be able to change it.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Thu, Jan 22, 2009 at 9:51:47 PM | Panel selection in curtain walls
renatolemus
Thank you very much!!!, you made my day!
Tue, Jul 22, 2014 at 4:54:07 PM | Panel selection in curtain walls
iceylove
Thank you very much! You solved my problem too
Panel tags for glass doors with frame in curtain walls
Thu, May 1, 2014 at 7:51:49 AM
Schedule curtain panel by level?
Fri, Sep 2, 2016 at 4:40:26 PM
Scheduling "System" Curtain Walling Panel Parameters
Thu, Aug 28, 2014 at 9:35:37 AM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:08 AM
Walls used as curtain panels - stop joining
Mon, Feb 23, 2015 at 8:14:14 AM
Page generation time: 0.8468
