64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> looking for a 3d animator???
Wed, Jan 21, 2009 at 1:38:51 PM | looking for a 3d animator???
intern
We have a client that wants a 30second fly-by.  We have massing model with several housing units and bunker built in Revit Architecture 2009.  Need to input landscaping, people and topography.  Is it possible to export Revit into Google Earth?  How much do you think we should budget?  please help.
Wed, Jan 21, 2009 at 6:22:28 PM | looking for a 3d animator???
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi intern, I recommend to you that export your Revit file in .ifc file type. Download "ifc2skp" and import your .ifc file into sketchup with this plugin, so you will get the same aspect that you have in Revit of your drawing in sketchup, make changes if you want and then export to Google Earth. About budget maybe someone else could help.....
Mon, Feb 16, 2009 at 3:44:07 AM | looking for a 3d animator???
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
one obvious thing about animation is that every frame has to
be rendered.. that could really take a long time..
seems like several rendered views would be more practical..
Mon, Feb 16, 2009 at 6:18:54 AM | looking for a 3d animator???
Annnte
You could export the project to a 3d dxf, dwg or fbx, and make the animation in 3ds max. That is how we do it... But, you will spend alot time on rendering. If you dont have time to wait you  could send the complete *.max file to a renderfarm. That will cost some money, but you will save some time.
 Stian
Mon, Feb 16, 2009 at 9:33:48 PM | looking for a 3d animator???
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i don't know too much about animation- i'm
just using logic.. if you want to animate- i guess 3Ds max
would be good for that because no matter how long it took-
that program would do it automatically- maybe over night..
when the camera moves around the model then you get
real 3D viewing.. but to a certain extent you can also see the
third dimension by viewing from several perspective views..
Software of Choice for Construction Animations?
Fri, Aug 12, 2011 at 10:53:13 AM
Revit 2010 to 3ds Max 2010 Problem
Wed, Jul 29, 2009 at 5:26:38 PM
Page generation time: 1.8989
