65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Catch a spot elevation into a tag
Tue, Jan 20, 2009 at 11:09:52 AM | Catch a spot elevation into a tag
FJ22
Hello all,
 I'm wondering if the following is possible (see also the attached PDF)
In AutoCAD we used to have a block with multiple information about a slab. The decription and comment are no problem to put into a tag, but it seems i can't put a spot elevation in the tag.
Is there a way to make something that looks like the AutoCAD block or do I have to make it with single lines etc.
Spot Elevation tag
Tue, May 6, 2014 at 12:41:09 PM
Spot elevation Tag and Insulation
Wed, Jun 11, 2014 at 10:00:27 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Tue, Aug 28, 2018 at 10:51:10 AM
Page generation time: 0.5492
