84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked rvt into another rvt
Tue, Jan 20, 2009 at 9:22:58 AM | Linked rvt into another rvt
Dafpfy
3.5 Stars: 11 Votes
it doesnt seem to be possible to have a file with linked in rvt files, and then link this file into and other rvt file,
or is there a way?
Kind regards,
D
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Jan 20, 2009 at 9:43:38 AM | Linked rvt into another rvt
I am working with a nested linked file right now so it is possible.  I don't know what you are doing wrong.  Did you verify the paths for the nested link is correct?
Tue, Jan 20, 2009 at 9:49:24 AM | Linked rvt into another rvt
Dafpfy
3.5 Stars: 11 Votes
The model you are linking has other models linked into it.
These links wil not be visible in this file,
this is what revit tells me,
peace is the path."
Mahatma Gandhi.
Tue, Jan 20, 2009 at 11:06:42 AM | Linked rvt into another rvt
Check out your H E L P  - Here is part of it "
Linking Revit Models that Contain Links
When you import a Revit model that contains a linked Revit model, links become nested. You can show (or hide) nested linked models in the host model. By default, nested linked models are not visible in the host model."
Tue, Jan 20, 2009 at 12:21:13 PM | Linked rvt into another rvt
Dafpfy
3.5 Stars: 11 Votes
Got it to work Smile
TNX!! WWHub
peace is the path."
Mahatma Gandhi.
Tagging rooms in linked RVT files
Wed, Dec 13, 2006 at 1:48:03 PM
linked revit structure.rvt
Fri, Jun 21, 2013 at 11:18:52 AM
Deleting Linked RVT Categories
Fri, Feb 3, 2006 at 9:40:29 AM
RTE vs RVT
Thu, Sep 26, 2019 at 9:21:04 PM
save as from template to rvt
Wed, Feb 15, 2012 at 6:31:16 PM
Page generation time: 0.7555
