80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> rendering elevation
Sat, Jan 17, 2009 at 1:20:37 PM | rendering elevation
71veedub
hi everyone, can revit 2009 render the elevation view? i tried to render the 3d view(fronT) but its not scaled. please help gurus
Sat, Jan 17, 2009 at 4:04:36 PM | rendering elevation
4 Stars: 202 Votes
Hi and Welcome to Revit World, see this: http://screencast.com/t/W3FN6pavUUW
Sat, Jan 17, 2009 at 4:40:02 PM | rendering elevation
71veedub
Typhoon, Thank you very very much! ,wow! awesome!Smile
Sat, Jan 17, 2009 at 7:16:02 PM | rendering elevation
4 Stars: 202 Votes
You Welcome...
Mon, Jan 19, 2009 at 4:18:12 PM | rendering elevation
71veedub
hey typoon, thanks alot, now i know how to render elevation, im just having hard time getting the right scale, after rendering the elevation, i put in to the sheet i made, and campare it to elevation view(shading with edges), sometimes theyr not the same, why is that? same in section rendering..thank you very much in advance,good day
Tue, Jan 20, 2009 at 2:41:19 PM | rendering elevation
4 Stars: 202 Votes
Like what??? can you put some images to check???
Wed, Jan 21, 2009 at 11:21:42 AM | rendering elevation
71veedub
here it is typhoon, elevations are in scale but not the section, thnks in advance
Tue, Sep 22, 2009 at 9:28:45 AM | rendering elevation
christoph99
Typhoon, all ...
 The link is broken ... is there another video I could watch re: rendering elevations?
Sun, Oct 4, 2009 at 7:10:42 PM | rendering elevation
Atraktzi
Yeah is there a fresh link? Sounds very useful.
Thanks
Fri, Oct 23, 2009 at 1:25:05 AM | rendering elevation
EssG
Second that!!
Link still broken
Wed, Oct 28, 2009 at 7:13:30 PM | rendering elevation
#11
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
before using camera tool just unclick perspective in top menu, next to scale, it is only thing you have to do and then just render your elevation
Wed, Oct 28, 2009 at 8:42:37 PM | rendering elevation
#12
EssG
Thanks Stankovic, will give it a go.
Wed, Oct 28, 2009 at 8:44:25 PM | rendering elevation
#13
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Just create a 3D View and then click on the side of the cube you want to render......
Edited on: Wed, Oct 28, 2009 at 8:49:40 PM
Fri, Nov 20, 2009 at 8:06:04 AM | rendering elevation
#14
JimNoth
... Or if you want a hint of perspective in your view to take away the "flatness" of an elevation, make a perspective camera and move it very far away from the building, then crop down to the region you want to render.  We do this quite often - even though it isn't to scale.
Ground Plane in Rendering
Tue, Feb 22, 2005 at 2:25:55 PM
Elevation Rendering
Mon, Nov 2, 2009 at 2:49:07 PM
Elevation rendering - roof shadows
Wed, Jun 16, 2004 at 1:13:01 PM
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:38 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:40 AM
22
Page generation time: 2.0827
