52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> angled parapet caps not connecting
Fri, Jan 16, 2009 at 11:25:29 AM | angled parapet caps not connecting
velvetseas
Hi-
I have an angled wall with a sweep at the top for a parapet cap.  I added the brick corbelling and cap by editing the profile of the wall type.  But, as you can see, the angled wall is throwing a wrench in things.  Is there a way to make the cap and corbelling wrap around?  The only thing I can think of is that I would have to remove the corbelling/cap from the wall type profile, and make them separately modeled sweeps.  I have tried to change all the "wrapping" options, without luck.
Thanks for your help in advance.
Fri, Jan 16, 2009 at 11:25:53 AM | angled parapet caps not connecting
velvetseas
I should add I'm using Revit Arch 2009
Fri, Jan 16, 2009 at 12:31:32 PM | angled parapet caps not connecting
tim123
4 Stars: 19 Votes
I don't seem to have a problem with this - is it your wall junctions?
Fri, Jan 16, 2009 at 12:42:12 PM | angled parapet caps not connecting
velvetseas
Hmmm....I attached an image of my walls in plan.  Is that where one would notice a wall junction issue?
 I added the top sweeps after the wall was already in place.  Would that have any affect on things?
Fri, Jan 16, 2009 at 3:43:41 PM | angled parapet caps not connecting
tim123
4 Stars: 19 Votes
I think that this is where your problem lies.  If I look at your first image it seems as if the walls don't clean up properly.  I dont see a problem in the plan.  Have you overidden or edited it in some way?  Try a new trial non-ninety degree corner with the same wall type and see if you replicate the problem.
Fri, Jan 16, 2009 at 3:47:52 PM | angled parapet caps not connecting
velvetseas
That might be my issue.  I tried a new sample wall, and the top cleaned up perfectly.  I had edited my wall profiles to insert the inset brick paneled wall.....perhaps that altered something.
wall sweeps
Fri, Aug 19, 2011 at 1:38:59 PM
Angled Wall Sweep End
Thu, May 7, 2009 at 10:56:28 AM
Arial Caps
Tue, Jul 12, 2011 at 8:37:49 AM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
Isolated foundations (pile caps) on sloping surface
Wed, Nov 15, 2006 at 11:17:20 PM
Page generation time: 0.2223
