82 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Interior Elevation call out link to room name?
Thu, Jan 15, 2009 at 7:01:07 PM | Interior Elevation call out link to room name?
james840a
Im still learning revit, and want to know if there is a way, when i create a new interior elevation, that it takes and /or links to the room name.  Because right now im having to rename each elevation manualy to the room name, and its taking to long.
Thanks,
James
Using Revit 2009
Fri, Mar 20, 2009 at 1:11:18 PM | Interior Elevation call out link to room name?
atkinsonhall
i must bump this post. it sure is a pain to have to rename every interior view to correspond with the room name. any ideas?
Fri, Mar 20, 2009 at 1:47:50 PM | Interior Elevation call out link to room name?
Sorry - you can't do this.
But if the elevations are all named the same like Room 100 Elevation, you can create the callout sequentially so they are all together in your browser, then highlight them all and change their name on the sheet all at one time.  You might also want to add a sort parameter to the views so they stay together... like "Elevations Room 100" and that could be filled in at the same time.  .... no need to change Revits default view name then because the views would be sorted by room name.
Interior Elevation Tag - adding Leader
Sun, Feb 17, 2008 at 8:36:29 PM
Interior Elevation not visible in drop down
Thu, Feb 6, 2014 at 9:19:32 AM
1st actual project in Revit Questions
Fri, Oct 19, 2007 at 3:37:27 PM
Why Interior Elevation Sequential?
Tue, Sep 13, 2011 at 4:54:00 PM
View/ Interior Elevation Legend
Tue, May 12, 2009 at 12:58:01 AM
Page generation time: 1.1301
