105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> adding a render system to an existing wall
Thu, Jan 15, 2009 at 4:52:59 PM | adding a render system to an existing wall
jonezy
hey guys im having a serious problem with my model... i have an external existing wall which has a rendder system on it but this sis being removed and a new one added, but im having a problem joining the new to existing and then getting my proposed windows to cut both walls!!
anyone come across this before ill post a sketch when i get into work in the morning to help explain my predicament...
cheers
Thu, Jan 15, 2009 at 6:24:21 PM | adding a render system to an existing wall
snowyweston
Unless the modelling detail of the render system requires framing elements (in which case you will be no doubt be better served by using a curtain wall type) surely you can just edit the compound layers of your existing wall type to reflect the new system's materials?
Fri, Jan 16, 2009 at 4:57:25 AM | adding a render system to an existing wall
tim123
4 Stars: 19 Votes
An image would be helpful to understand your problem.
Existing Wall Rendered
Sun, Jul 27, 2008 at 5:23:30 PM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
existing floor system
Tue, Mar 6, 2012 at 10:02:21 AM
new wall finish over existing wall
Thu, May 7, 2009 at 10:46:37 AM
Existing wall cut by new wall even in existing view
Wed, Dec 13, 2017 at 1:11:12 PM
Page generation time: 1.8550
