95 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Baluster Question
![quiller Avatar](user_avatar/665.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
How do I get 2 baluster pre thread and have both connected to the thread. I can only seem to get one to connect and the other is higher, and I'm assuming it's following the angle of the stringer.
Cheers, Alan
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Change the baluster offset to 0.
If it were that easy!!!!! Please check out the attached doc and let me know what you think.
Alan
Providing you have baluster's per tread set to 2 and there base set to host and the baluster is completely on the tread in section (not half overlapping which is why i suggested the above) then it should work no problems.
I just tested it and worked a treat.
HTH.
rail 1 and baluster heigth |
Tue, Nov 8, 2011 at 10:40:22 AM
custom baluster with decorative piece not staying equal 2019 |
Thu, Jun 14, 2018 at 1:54:47 PM
Need help! Custom baluster |
Mon, Apr 20, 2015 at 7:40:11 AM
Baluster Height Issue |
Tue, Nov 6, 2007 at 6:37:15 PM
Newbie help: how to intersect railing with baluster |
Wed, Mar 25, 2009 at 4:26:53 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
