Forums >> Revit Building >> Technical Support >> Purge Materials?
Is there a way to do this? thanks, Lorne
Denver, CO
Revit Architecture |
No you cant do this.
File - Purge Unused I always click the 'check none' option 1st, then go thru an select the things I want to pitch. You can really get yourself in trouble if not. Well, at least I have...
you can purge unused components but that I know you can´t do that with the unused materials, you have to erase them one by one.....
“Learning never exhausts the mind.” — Leonardo Da Vinci
61 Posts No Rating |
It might not save you this time if you're mid-modelling; but ahead of having an agreed CAD/BIM-protocol-compliant template file; I've recently been promoting the use of a purged (and pre-loaded) .rvt file for the starting of new projects within our office; you need only cull the materials (and any other unwanted families, components etc) once on a blank project - then use that as your starting point in future.
" It might not save you this time if you're mid-modelling; but ahead of having an agreed CAD/BIM-protocol-compliant template file; I've recently been promoting the use of a purged (and pre-loaded) .rvt file for the starting of new projects within our office; you need only cull the materials (and any other unwanted families, components etc) once on a blank project - then use that as your starting point in future. " This is exactly what I'm trying to set up. Although the project I'm working on is mostly to the standaards we want for our projects so I am trying to get rid of everything unwanted then I plan to transfer project standards. Materials were part of the unwanted items I'm trying to get rid of.
Denver, CO
Then sadly it's a case of manually delete/enter/delete/enter/delete/enter - took me only a minute or so.
how I purge or delete materials not used?? [ 1 2 ] |
Wed, Sep 9, 2020 at 8:27:42 PM
15
MATERIAL PURGE |
Mon, Jul 5, 2010 at 9:27:58 AM
Serious problems with a "tough" material |
Thu, May 5, 2016 at 2:31:30 PM
Text style that I can't get purge |
Wed, Sep 5, 2012 at 8:40:41 AM
purge selected |
Wed, Sep 17, 2008 at 10:40:42 PM
Members: | 2115328 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
