55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exporting to Autocad with identical basepoints relative to project
Wed, Jan 14, 2009 at 2:37:37 PM | Exporting to Autocad with identical basepoints relative to project
everist
3 Stars: 2 Votes
Hello,
I need to export dwg backgrounds for my mechanical engineer. They have requested that my dwg exports share identical base points so the dwg's overlay in the same place on every floor.
Shy of manually adjusting the exports every time I export, please advise as to how I may achieve this desired result.
 Thanks,
Wed, Jan 14, 2009 at 3:57:16 PM | Exporting to Autocad with identical basepoints relative to project
Actually, the model will always export to the same place but if you export from sheet views, the autocad viewports may not be the same sheet to sheet.  If they want that, let them set their own viewports and just export views.
Wed, Jan 14, 2009 at 4:13:12 PM | Exporting to Autocad with identical basepoints relative to project
everist
3 Stars: 2 Votes
That makes sense and helps. We were exporting from sheets.
exporting to autocad
Tue, Jan 30, 2007 at 11:32:23 AM
Importing from & exporting to AutoCAD
Wed, Nov 2, 2005 at 10:10:25 AM
Relative coordinates
Wed, Nov 7, 2018 at 4:03:00 AM
Trouble w/ exporting to AutoCad
Thu, Jan 20, 2011 at 11:18:08 AM
Group instances of the same type do not contain identical members
Sat, Jan 23, 2016 at 7:57:38 PM
Page generation time: 1.1173
