Forums >> Revit Building >> Technical Support >> IMPORTING TOPOSURFACE PLEASE HELP
SO HERES THE DEAL I AM TRYING TO GET MY TERRAIN INTO THE DRAWING BUT FOR THE LIFE OF ME i CANNOT IMPORT IT. i HAVE THE DWG IT HAS "Z" AXIS VALUES. SO I CALLED THE SURVEYOR AND ASKED FOR IT IN CSV FORMAT AND DXF FORMAT. CAN SOME ONE SEE IF I'M MISSING SOMETHING OR IS IT THE FILE. BTW I AM RUNNING RAC 2009
Your DXF file is Corrupted, try to create a new one, about CSV file see this by the HELP menu....
THANK YOU FOR YOUR QUICK RESPONSE TYPHOON. I HAVE BEEN RACKING MY BRAIN FOR 2 DAYS. i READ THAT FILE AND EVEN TRIED MODIFYING THE CSV FILE WITH DO LUCK. THIS IS THE FIRST TIME I HAVE TRIED IMPORTING A SURFACE. i HAVE FOLLOWED MANY OF YOUR POSTS AND FIND YOU TO BE VERY KNOLEDGEABLE IN REVIT i HAVE ATTACHED THE DWG MAYBE THE PROBLEM LIES IN THERE?
Hi, see this: http://screencast.com/t/UgZ11JfM
i FOUND MY PROBLEM IT i HAD THE THIS VIEW ONLY BOX CHECK. IT WAS NOT ALLOWING ME THO SLECT THE FILE. THANKS SO MUCH TYPHOON. YOU TRULY ARE A REVIT GURU LET ME KNOW IF i CAN RETURN THE FAVOUR
LOL, you Welcome....
importing topo info into RAC 2010 to create a toposurface |
Thu, Apr 29, 2010 at 1:12:40 PM
A toposurface problem? |
Mon, Sep 18, 2006 at 9:16:10 AM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations |
Thu, Aug 27, 2009 at 1:51:06 AM
Members: | 2118797 | Objects: | 23205 | Forum Posts: | 152309 | Job Listings: | 3 |
