Forums >> General Discussion >> Revit Project Management >> New window not loading correctly?
2 Posts No Rating |
Hi, I have created a new window family and it looks correct in all the views but when i insert it into my project it doesnt cut the wall properly and parts of the mullions and pieces of glass are missing. Any help would be appreciated! I have attached the window i created
Hi Lauraj, do you know how you create a family??? I think first you must check this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739
2 Posts No Rating |
Yes... i have made them before without problems
NO, if you check the family try to flex them, don't work, you don't have dimensions/parameters to constrain the ref. planes, you dont lock the objects to the ref. planes and so one....
Complex Window Families |
Wed, Mar 3, 2010 at 1:42:29 PM
Window mullin profiles not loading, 2011 |
Wed, Aug 18, 2010 at 5:01:21 AM
Window not showing up correctly in wall? |
Thu, Feb 7, 2008 at 10:40:22 AM
Render in cloud window not displaying correctly |
Thu, Apr 21, 2016 at 1:53:14 PM
Window Family not cutting correctly |
Thu, Aug 26, 2010 at 3:30:51 PM
Members: | 2119072 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
