100 Users Online (99 Members):
Forums >> Revit Building >> Tips & Tricks >> Trick: Fading elevations
In 2D CAD software, one would normally draw a building elevation with the areas closest to you in a thicker line, and use thinner lines as sections of the building are further away from you. I had a problem with Revit automatically giving me the elevations all in one pen-line thickness; thus one cannot distinguish between what is closer or further on the elevation. This can be overcome by drawing a few large sheets of glass cutting through the building (on plan). Set the transparency of the glass to 50%. Then hide the panes on plan. On the elevation the view would seem faded where you see a portion of the building through a pane of glass. A further portion of the building would seem faded even further if a second pane of glass is introduced between the first pane of glass and the building face. One would then crop the elevations, so that the glass edges are outside the crop-boundary, thus not visible. It's tough describing the method in words; but it works like a bomb! If anyone has better ways of getting that 'fading" effect, pls let me know...
1 Posts No Rating |
Have you tried using linework tools to define darker/heavier lines etc... it seems like the glass would distort the integrity of the model.
The method that I prefer is to duplicate the elevations and adjust the view range in each to only show the relevant part of the elevation. Each elevation can be faded to the relevant degree and snapped together on the sheet.
Definitely a trick worth trying out. Thanks Tim123!
14 Posts No Rating |
I just right click, Override Graphics by Element. Pretty simple really.
Talk about beating a dead horse!
Trouble importing AutoCAD survey into an existing buidling model |
Mon, Oct 31, 2005 at 5:18:37 PM
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
Improving Linework in Sections & Elevations |
Sun, Mar 30, 2008 at 12:30:48 AM
how to add elevations to door & window schedules |
Tue, Oct 30, 2007 at 11:59:24 AM
Topography and pads trick |
Mon, Jan 14, 2013 at 2:53:18 PM
Members: | 2056433 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
