116 Users Online (114 Members):
Forums >> Community >> The Studio >> PDF?
4 Posts No Rating |
Is the ability to print to PDF gone in Revit 8???
You can still print to PDF, the Revit PDF printer is just no longer included in the install. It's available from the Autodesk Revit Download centre should you require it.
HTH.
7 Posts No Rating |
Unfortunately, it's not there anymore either.
1 Posts No Rating |
Apparently, due to technical complications, the 'Pine Bush' PDF writer is not being distributed with Revit Building 8.
I suggest that you use 'Cute PDF' instead, and can be downloaded FOC from...
http://www.acrosoftware.com/Products/CutePDF/writer.asp
I agree - in my opinion this is a superior (and free!) PDF driver, that works in all applications, not just Revit. I had all sorts of margin problems with the Pinebrush driver that dissappeared with CutePDF.
16 Posts No Rating |
We use Adobe Acrobat Profession V 6.0. It just works! I hear the current V7.0 software works well also. It can create all the different sheet sizes and no one ever has a problem displaying or printing the PDF. It is “real Adobe” PDF after all. Sure it would be nice if Revit had a free tool for creating PDF but the same Acrobat tool works well with all my other software. It make PDF printing a non issue and one less thing to think about is a good thing.
I have to agree, Adobe 7 is just great! I never had to much fun with the Revit PDF writer, and I think it would be nice if Autodesk did some more work on it...
will give cutePDf a go and see how it is though
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND?? |
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names |
Thu, Apr 7, 2011 at 8:37:37 AM
pdf print |
Thu, Sep 25, 2014 at 6:04:04 PM
pdf |
Sun, May 7, 2017 at 5:12:30 AM
11
Print to PDF |
Fri, Jan 23, 2015 at 6:47:45 AM
Members: | 2058000 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
