52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Missing Objects in Section View
Wed, Jan 14, 2009 at 4:57:16 AM | Missing Objects in Section View
Adiadum
Using Structures '09, I have a sink and a toilet placed in the bathroom on Plan 1.  I placed a Section through the bathroom which cuts both the sink and toilet.  However, neither appear in the Section View.  I have checked the Interior Elevation and both appear there.  I have played around with the Visibility Parameters in both the Section View and for each of the families as well and can't get it to appear.  Am I missing something?
Wed, Jan 14, 2009 at 5:29:51 AM | Missing Objects in Section View
4 Stars: 202 Votes
Hi, in Revit there are "Cuttable and Non-Cuttable" families, search that in the HELP menu....
Wed, Jan 14, 2009 at 5:40:58 AM | Missing Objects in Section View
Adiadum
I know that they area non-cuttable families, however they should still appear in the View regardless.  I have toilets and such in drawings in Revit Arch which appear when cut through.  However, they appear as projections.  I cannot get them to appear at all in Structure.
Wed, Jan 14, 2009 at 8:45:54 AM | Adiadum
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Adiadum from 2009-01-14 05:40:57
"I know that they area non-cuttable families, however they should still appear in the View regardless.  I have toilets and such in drawings in Revit Arch which appear when cut through.  However, they appear as projections.  I cannot get them to appear at all in Structure."
the section view itself is probably set to Structure, and will only display structure elements with that setting.???
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 14, 2009 at 9:08:52 AM | Missing Objects in Section View
Adiadum
I thought of that too so I changed the Section View to Architectural and still got nothing...thanks for the suggestion though!
Wed, Jan 14, 2009 at 9:28:24 AM | Missing Objects in Section View
JACMD
If you are trying to show toilets in revit structure try putting your discipline in coordination.
Section View with missing objects at certain height!
Tue, Mar 10, 2009 at 10:41:05 PM
Missing objects in section view (????)
Thu, Mar 25, 2010 at 8:45:55 AM
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:16 PM
Section callout missing
Mon, Dec 16, 2013 at 4:00:10 PM
Section callout missing yet Section still Exists
Mon, Feb 20, 2012 at 3:34:47 PM
Page generation time: 0.8930
