107 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> exterior wall material pattern
Tue, Jan 13, 2009 at 3:08:16 PM | exterior wall material pattern
RainaMc
RainaMc Avatar
My siding hatch pattern does not line up.  How can I fix this?
Tue, Jan 13, 2009 at 3:14:33 PM | exterior wall material pattern
tim123
4 Stars: 19 Votes
Select a pattern line (use tab key) and move it to the required position.
Tue, Jan 13, 2009 at 3:16:50 PM | exterior wall material pattern
4 Stars: 201 Votes
"Align" tool...
Tue, Jan 13, 2009 at 3:26:16 PM | exterior wall material pattern
tim123
4 Stars: 19 Votes
Yeah, align tool is quicker.
Tue, Jan 13, 2009 at 3:31:07 PM | exterior wall material pattern
RainaMc
RainaMc Avatar
Thank you thank you Tim123 worked like a dream.  I had no clue that could be done.  That has been bothering me since I started working with Revit.
Thanks again,
Raina Mc.
Tue, Jan 13, 2009 at 3:34:57 PM | exterior wall material pattern
RainaMc
RainaMc Avatar
Just got Typhoons post thank you.  However I could not get the align tool to work.  It will pick the pattern line i want to align to but not the one I want to align.  Although the other way seems pretty easy and quick to me.
 Thank you both
Tue, Jan 13, 2009 at 3:39:04 PM | exterior wall material pattern
RainaMc
RainaMc Avatar
Oops nevermind i got it to work.
Thanks again!
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
Is there a way to find out the material that is "painted" on surface of a model?
Tue, Dec 14, 2010 at 3:44:58 AM
Material take off - is this a bug?
Mon, Jan 24, 2011 at 8:15:10 PM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
Page generation time: 2.1708
