Forums >> Revit Building >> Technical Support >> How Do I Make My Fill Pattern Show In 3D View
78 Posts No Rating |
The building I'm designing at the moment has a red brick exterior but there are 3 bay windows and underneath these windows I want the brick face rendered (sand and cement style). I have worked out so far how to do a pattern fill by going into draughting etc, and using the filled pattern option, but this only shows my pattern when in one of my elevation views. If I click 3d view, my pattern doesn't show. What do I need to do to see the pattern I have created in 3d view also? Many thanks
----------------------------------- USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes. |
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
did you add your pattern to the surface pattern of the material?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
![4 Stars: 19 Votes](/images/stars_4.gif) |
It may just be the angle. When the viewing angle is too acute Revit does not show the pattern.
[QUOTE: did you add your pattern to the surface pattern of the material?] Not sure how to add pattern to surface material! Is there anything specific I need to do here? Tried looking at my model in different angles in 3d mode etc but it still doesn't show my fill. Thanks for anymore help on this.
9 Posts No Rating |
Hey well when you add pattern to the material go to 3D view and turn on "Shading with Edges" or "Hidden Line" view mode and i thing you won't have any problems.
9 Posts No Rating |
And you can add surface pattern in Settings/Materials, find the exact one and in the "Surface Pattern" add what you wish.
There are two patterns in REVIT. 2D patterns - drafting - that will show in any 2d view but are view and 3d patterns - model. Read up on these in your help and you will learn when to use them.
Still must be doing something wrong. I went into 3d mode and I already had shading with edges turned on. Also tried 'hidden line' but still, the fill pattern I have that shows in South elevation view does not show in 3d view. But, I went into settings > materials > render - beige smooth > render appearance, and I love this stucco type finish that I have just seen. This is better than the colour fill that I was initially trying to do. Now, how do I take that material I just mentioned and apply it to underneath my bay windows as mentioned in my original post. This would be fantastic if I could get this finish on my model. I have no idea how to go about this so please can you describe the prosess to in simple terms. I want to be able to see the pattern in 3d view. Many thanks for these replies so far by the way. Kirk
You need a different type of wall beneath the window. Split the face and use the paint bucket tool to apply that material or create a different wall beneath the window with the correct finish incorporating that material as the finish.
Fill Pattern not show up when print |
Wed, Apr 25, 2012 at 4:08:55 AM
Diifferent solid fill color and pattern for submission to different department |
Tue, Jul 22, 2008 at 3:54:39 AM
Revit 2015 Solid Cut Fill Pattern |
Thu, Sep 22, 2016 at 8:27:54 AM
create a custom fill pattern [ 1 2 ] |
Mon, Jun 28, 2021 at 2:32:51 PM
29
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
