19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Quit Deselecting My Selection!
Tue, Jan 13, 2009 at 9:50:37 AM | Quit Deselecting My Selection!
DarkenRahl
When I cancel a command, it does not mean I want to deselect the set that i spent 5 minutes making.  Either (pleeease) add the ability to enter selection sets into memory (a'la Photoshop) or simply have a two level (optional) cancel, once for the command and once more for the selection set.
Thanks.
Tue, Jan 13, 2009 at 9:59:11 AM | Quit Deselecting My Selection!
vihi
Right click in the view and choose "Select Previous"?
Tue, Jan 13, 2009 at 10:17:09 AM | Quit Deselecting My Selection!
DarkenRahl
If I select a set of objects to move, then accidentally click the Copy Command Button instead, hitting escape drops my selection, and select previous only works with objects that have had a command completed with them.
I appreciate the suggestion, though.  Thanks.
Tue, Jan 13, 2009 at 10:24:45 AM | Quit Deselecting My Selection!
vihi
You're right, it doesn't really help.
What's weird though is that if you select an object and then just click somewhere else to deselect it, "Select Previous" works as it should even though select/deselect is not really a command.
Erratic behaviour, to say the least.
selection issue
Fri, Mar 4, 2005 at 3:43:11 PM
selection filter
Sun, May 21, 2006 at 9:32:56 PM
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:16 PM
Tag all not tagged by selection help
Fri, Feb 17, 2012 at 1:28:08 PM
Rule-Based Filter SELECTION
Sun, Dec 9, 2018 at 6:56:29 AM
Page generation time: 0.2217
