60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> View Depth and Line Weights
55 Posts No Rating |
Does Revit make an adjustment for line thickness based on the distance of the object from the cut plane? I have a roof plan in which the parapet walls that are lower are showing up really light, and nothing I do with the graphic overrides seems to make a difference. I've tried everything, and the lines look the same. Any advice would be much appreciated... Thank you!!
You might be looking at an underlay - its the floor below. If so, adjust your view depth in your plan to include the parapets.
I would look at the lineweight assigned to the line style called BEYOND. I believe the default is set to 1. This line style controlls what is below the bottom level. HTH
Yeah Brett, but if you change that line style affect all model (all views), if he/she want only in that view i think it's better change only the View range like Tim says....
Edited on: Mon, Jan 12, 2009 at 2:45:09 PM
Thanks for all the help - I adjusted the "beyond" line type and it worked like a charm!
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Line weights & detailing 2012 |
Thu, Jun 6, 2013 at 7:51:24 PM
Line Weights not showing in View |
Tue, Jul 8, 2014 at 12:45:18 PM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
Members: | 2030522 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
