94 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> Right/Left-hand doors
1 Posts No Rating |
Hello! I'm new here. I hope you can help me. I'm finding impossible to separate doors (in a door schedule) by those which are left-hand and right-hand doors. Is it possible to do in Revit'09? Does Revit recognize which side the door opens? How? Thanks for your help!
1 Posts No Rating |
Hello, I'm trying to setup my doorschedule where Revit 09 automatically calculates if the door has a left or right hand swing, too. Is this possible? Thanks.
9 Posts No Rating |
You could try reviTTools, it's not free but can supposedly be run in demo mode without limitations. http://www.revittools.info/
![5 Stars: 4 Votes](/images/stars_5.gif) |
Here is an app that does that:
https://apps.autodesk.com/RVT/en/Detail/Index?id=2481590927896495348&appLang=en&os=Win64
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
0 Posts No Rating |
This actually can be solved easily with a little help of Revit API. After so many years, Autodesk did not implement this option so I created custom updater which reacts on flip and mirror event on doors and windows, please read more here:
https://www.engipedia.com/api-custom-flipped-mirrored-elements-updater-in-revit/
Also, notice that it saves information if element is flipped or not into "Area" parameter type. The only reason is because of groups and formulas, read more details on the link.
Add-in is free. I hope it will be of good use.
How to make doors flippable in family? |
Wed, May 30, 2007 at 8:23:48 PM
Couniting left or right doors??? |
Sun, Jun 12, 2005 at 12:52:51 PM
can't add hand rail |
Thu, Feb 26, 2009 at 6:35:39 PM
Section Tag Head/ Line issues |
Wed, Apr 19, 2017 at 5:38:39 PM
Ergonomic mouse substitute |
Thu, May 2, 2013 at 10:14:55 PM
Members: | 2022458 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
