Forums >> Revit Building >> Technical Support >> Sky properties in r2009
in r2008, one could customize the sky: color at horizon, cloud density, colors etc. I can't find a way to select anythying in r2009 other thatn in rendering/background/style/ then pick from +/- 6 choices. is that right?
Are you talking about in 2008 you can put whatever you want in the background render and now in 2009 you can't???
no, in r2008 you could manipulate the color of the sky, the color getting darker at the horizon the color and quantity of clouds: in r2009 you seem to only get 6 stock picks for sky.
Hi SteveB, of course you can manipulate the sky in Revit 2009, although it looks not so real. You can do it by changing the time of the day or the azimut (see the image).
“Learning never exhausts the mind.” — Leonardo Da Vinci
Rendering with no sky. |
Sat, Mar 21, 2009 at 2:50:00 PM
11
Trouble with sky for rendering |
Wed, Jul 21, 2010 at 9:10:27 AM
host sweep not working in R2009 when roof fascia option used on ridge and hip li |
Sat, Sep 26, 2009 at 10:07:01 AM
RAC 2009 Sky Rendering Problem |
Thu, Jul 10, 2008 at 7:37:37 AM
How do you get a sky? |
Fri, Nov 26, 2004 at 4:42:16 PM
Members: | 2100548 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
