147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Zero Suppression in Level elevations
Mon, Jan 12, 2009 at 12:54:56 PM | Zero Suppression in Level elevations
RevitCity07
I set my project units to suppress 0 feet.  The problem is that in my levels, at the ground floor it just says 0" now.  I guess it's doing what it's supposed to do, but in this one area I want it to say 0'-0"  Any help?
 Revit 2009
Fri, Jan 16, 2009 at 6:15:15 AM | Zero Suppression in Level elevations
tim123
4 Stars: 19 Votes
Go to the levels properties and you can overide the format for that particular annotation (under 'units format').
Fri, Jan 16, 2009 at 9:22:43 AM | Zero Suppression in Level elevations
RevitCity07
Level properties?  You lost me
Fri, Jan 16, 2009 at 9:46:39 AM | Zero Suppression in Level elevations
tim123
4 Stars: 19 Votes
If I understand your problem correctly, you have placed a level using the spot elevation tool, and in a particular view you would like to overide the number format.  If this is the case, go to its properties, duplicate the elevation symbol and overide the unit formatting - see image.
Fri, Jan 16, 2009 at 10:01:55 AM | Zero Suppression in Level elevations
RevitCity07
Ah, well that's the thing...it's not a spot elevation...it's actually a "level"
Fri, Jan 16, 2009 at 10:10:55 AM | Zero Suppression in Level elevations
I don't know a way to get rid of this because it reads the information as a real value that you set to 0.  You will have to use a level head that does not have this value.
Hiding Level Bubbles to internal elevations
Tue, Dec 10, 2013 at 4:10:46 PM
Level elevations
Thu, Sep 11, 2014 at 12:54:40 PM
Level Symbols on Elevations
Tue, Sep 15, 2009 at 8:26:21 AM
Problems with linked files and interior elevations
Wed, Aug 3, 2011 at 7:59:53 AM
Changing Level Elevations without moving the Model?
Tue, Sep 4, 2012 at 5:58:04 PM
Page generation time: 0.6530
