Forums >> General Discussion >> Revit Project Management >> 64bit demo
does anyone know if or how i can get a 64bit revit demo? it says go to subsriptions but says nothing there about a revit demo..
you can download the actual 64-bit version from the subscritption site, but i don't think there is 64-bit demo version(trail version). technically there is no demo version, you just run the actual program in demo-mode until you register it HTH
thanks- please help me figure out how to download the 64bit version from the subscription site.. i've been there several times i don't understand it..
have a look http://screencast.com/t/YSz3CDOonug
thanks coreed- that's what i'm saying- i go to that same address and it tries to steer me to an autodesk reseller phone number.. my normal autodesk sign-in doesn't work and it says this: You do not have a valid Subscription Center contract. To renew or purchase a subscription contract, or to learn more about the subscription program, please contact your Autodesk Authorized Reseller or Autodesk Sales Partner. how did you get there?
lemmi guess- you phoned your nearest autodesk reseller because you also wanted revit 64 and they told you to send them a thousand bucks- so then you sold you car and now you have a subscription and that's how you got revit 64 running in demo mode?
you will have to contact your re-seller or Autodesk if your subcription is not valid?
exporting demo layers |
Sat, Apr 21, 2012 at 8:15:27 AM
Joist on demo layer |
Thu, Aug 2, 2012 at 3:41:03 PM
Designjet printer driver w/ Windows 7 - 64bit |
Thu, Feb 17, 2011 at 11:20:25 AM
Creating a demo drawing?? |
Fri, Oct 5, 2007 at 10:31:14 AM
windows xp pro 64 bit OS |
Thu, Jul 21, 2005 at 6:29:18 PM
Members: | | Objects: | | Forum Posts: | | Job Listings: | |
