71 Users Online (69 Members):
Forums >> General Discussion >> Revit Project Management >> Fatal error, Now cannot open revit!
8 Posts No Rating |
I was working in a project. I was using texts at the time. I went to spell check my work and in the process of doing so a fatal error occurred. I saved & closed out. When I went to go back into revit I got this message: An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files. Now everytime I attempted to go into revit this message appears and it kicks me out. I use revit 09. I am hoping someone could help me with my situation. I appreciate it. Thank you
Hi, did you try to "AUDIT" the file??? did you try to "Import/Link" that same file into new project???
Hi, Duckitech, So,this means that you can't open your Revit now???? If it's so, the only way could be by reinstalling all again...and when done try what Typhoon says...audit your file before you open it again...
8 Posts No Rating |
I appreciate your help, once again.
Hi Duckitech, I forgot to tell you that you've to install the web update#3 servicepack for Revit 2009 too. You can download it from this website: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599.
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:40 PM
Fatal error on a shared job Revit 2015 |
Tue, Mar 15, 2016 at 1:06:32 AM
fatal error |
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error inserting components |
Mon, Nov 24, 2008 at 7:26:38 PM
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:43 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
