59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Replace Dimension w/Text Error
Fri, Jan 9, 2009 at 5:01:52 PM | Replace Dimension w/Text Error
JRMello
Anyone else have a this problem: I edit my dimension value to "Replace with Text" add text there and "Below" and close the box. All is fine up to this point. If I click on the text again to edit it, I get the normal window, but none of the text I entered is visible, and I then cannot Ok or Cancel out of that window in any way, and have to shut Revit down through the Task Manager. Weird.
RAC2009
Fri, Jan 9, 2009 at 5:28:05 PM | Replace Dimension w/Text Error
tim123
4 Stars: 19 Votes
Never seen this problem.  Does this happen with all dimensions or just a particular one?  If it is just that one, delete the dimension and redo it.
Mon, Jan 12, 2009 at 8:49:33 AM | Replace Dimension w/Text Error
JRMello
Well, it happened repeatedly with dimension strings that I would create in a particular area, so I moved on. Now in a new day, I can't seem to replicate the problem. Which I suppose is a good thing, until it inevitably pops up again when I have a deadline. Oh well.
Mon, Jan 12, 2009 at 9:39:27 AM | Replace Dimension w/Text Error
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Sounds like it just was on of those one time things, but if it happens again just send a message to Autodesk and ask them if they have run across the problem before. Since adding text to dimensions is a relatively new tool there is bound to be a bug or two in it.
REMOVING DIMENSION TEXT
Wed, Jul 2, 2008 at 9:31:23 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
equal dimension curtain wall NOT SHOWING EQ
Thu, Dec 8, 2016 at 9:01:53 PM
Dimension Inches w Replace text not working
Thu, Feb 27, 2014 at 7:13:14 AM
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Page generation time: 9.2398
