106 Users Online (105 Members):
Forums >> Revit Building >> Technical Support >> Rendering Split face block in RAC2009
10 Posts No Rating |
I'm trying to render different split face block colors in 2009 but every time I don't use the standard coral SF image I just get a solid color. I've bumped up the "bump" but i lose the course lines. What at i doing wrong? It doesn't seem to me that RAC 2009 handles the block rendering very well. Do I have to find a .jpg image the type of block I want to render? Thanks,
![4 Stars: 19 Votes](/images/stars_4.gif) |
You will need a different mapping image. Find the image and change the colour in photoshop or something similar and apply this to the different block. Altenatively, find a picture of the blockwork and create a map from it using photoshop.
I think I've found a solution to my problem. www.brick.com this website has a Masonry designer tool that lets you build a brick or block wall and export it out as an image. You can then take it into photoshop or any image editor and crop the file down. I don't think the resolution is as good as the images Revit comes with standard but it is a work around for now. Peter
Split Face Masonry Block |
Thu, Aug 3, 2006 at 6:25:54 PM
SPLIT FACE BLOCK |
Tue, Jul 18, 2006 at 10:41:24 AM
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:11 PM
Split face on floor? |
Wed, Nov 18, 2015 at 1:16:28 PM
Edit Split Face on Ceiling |
Mon, Jan 25, 2010 at 4:42:26 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
