144 Users Online (142 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Looking for quick Key shortcut
Fri, Jan 9, 2009 at 9:02:36 AM | Looking for quick Key shortcut
Vidaman
What is the Keyboard shortcut for 'element properties'?  it's not 'EP'.  I also can't find it in the Keyboard Shortcuts.txt.
I'm using Revit Architecture 2009.  Build: 20080915_2100.
Fri, Jan 9, 2009 at 9:17:45 AM | Looking for quick Key shortcut
tim123
4 Stars: 19 Votes
PR
Fri, Jan 9, 2009 at 9:21:36 AM | Looking for quick Key shortcut
Vidaman
AWESOME! THX TIM!
Fri, Jan 9, 2009 at 9:31:50 AM | Looking for quick Key shortcut
tim123
4 Stars: 19 Votes
No trouble - its in the edid menu BTW.
Fri, Jan 9, 2009 at 9:44:14 AM | Looking for quick Key shortcut
Vidaman
Sometimes the best hiding spot is in the most obvious place.
Wed, Jul 1, 2009 at 6:52:25 PM | Looking for quick Key shortcut (v2010)
cobblea
In versions 2010, I was trying to find a way to customize the "PR" shortcut--  Like many other users, I prefer a quick left handed shortcut for such a common and frequent task (that way I don't have to look at the keyboard and can work faster).  In v.2009, I had "``" (up by the esc key) set to take me to element properties, but now that the program has been re-worked, it looks like I can no longer customize this function.  Has anyone figured out a work-around, or should I just start re-training my muscle memory to hit "PR" now?  Thanks in advance.
Thu, Jul 2, 2009 at 4:26:12 AM | Looking for quick Key shortcut
tim123
4 Stars: 19 Votes
You can still change it.  See image.
Thu, Jul 2, 2009 at 10:22:20 AM | Looking for quick Key shortcut
cobblea
Thank you, that is just what I was looking for!  This new format will take some getting used to...
repeat command shortcut key??
Tue, Aug 19, 2008 at 2:15:13 PM
shortcut key for text
Tue, Jul 25, 2006 at 6:26:10 PM
Shortcut Key to Rotate 3D View
Wed, Dec 1, 2010 at 4:06:53 PM
Deleting Problems (Revit 2009)
Mon, Oct 27, 2008 at 9:21:16 AM
Keyboard shortcuts
Wed, Jul 2, 2008 at 2:14:30 PM
Page generation time: 0.5071
