45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to add the room color in section?
Fri, Jan 9, 2009 at 4:42:01 AM | How to add the room color in section?
goodnightren
I use the RAC2009. I add the room in the plan and I can see the color, but in the section I can see it even after I check the visiable. It doesn't work. What's the problem? Is there anything that I need to do?
Fri, Jan 9, 2009 at 8:33:00 AM | How to add the room color in section?
tim123
4 Stars: 19 Votes
In your section view, go to view properties and apply a colour scheme, set this to foreground.
Fri, Jan 9, 2009 at 12:36:39 PM | How to add the room color in section?
rquist
Can you tell my why when I pick "VIEW PROPERTIES" I get the "element properties" dialogue box and there is NO option for applying a color scheme.
Mon, Jan 12, 2009 at 3:02:23 AM | How to add the room color in section?
goodnightren
Thanks tim123, I find it.
There is another question. You can see the picture. The yellow are is the room in section, but it isn't been limited in the building, it exploses one cornner. I have clicked room bounding in the curtain system wall. I can't change the curtain system wall to roof. Because the curtain is made by mass face, from bottm to the top.
What could I do next step?
Mon, Jan 12, 2009 at 3:16:03 AM | How to add the room color in section?
goodnightren
To rquist
Yes, when you right click mouse in section view, you can find the view propertis (alos the element propertis), then youcan find the color scheme.
Thu, Jan 15, 2009 at 2:36:02 AM | How to add the room color in section?
goodnightren
Need help...
Thu, Jan 15, 2009 at 6:00:33 AM | How to add the room color in section?
tim123
4 Stars: 19 Votes
Did you solve this problem?
Fri, Jan 16, 2009 at 3:01:32 AM | How to add the room color in section?
goodnightren
Frankly, I know how to add the color in the section. But in the pic, I do per your suggest from anothe thread, but the 2nd section is still not right. I have given the boundery to the curtain wall,but it doesn't work.  Also the first and the 4th ones are not what I want. I want it like the 3rd one, filling the color full of the room. Maybe this is a bug in Revit, but is there anyway to make up it?
Thank you.
Fri, Jan 16, 2009 at 4:35:24 AM | How to add the room color in section?
tim123
4 Stars: 19 Votes
Check that the unbounded height is higher than the top part of the roof.
Fri, Jan 16, 2009 at 9:47:34 AM | How to add the room color in section?
hkempenich
Wish for 3-D
Mon, Jun 2, 2008 at 8:57:03 AM
How do I create a Room Tag that has a text field that I can add comments too?
Mon, Nov 20, 2017 at 4:22:21 PM
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Room name in section
Fri, Aug 30, 2013 at 7:39:26 AM
Toposurface Fill Color in a Section View
Fri, Jan 30, 2009 at 9:28:10 AM
Page generation time: 1.4303
