73 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Importing .dwgs into Revit
62 Posts No Rating |
When I export Revit drawings to Auto CAD I'm having problems getting the Auto CAD drawings back into Revit. Nothing comes into Revit and if it does then its too large. I need help. Someone call a medic.
admin
hehe, if you could provide some additional information, I just tried it and it worked fine.
Hiroshi Jacobs
The Catholic University of America |
Revit automatically exports my drawings into AutoCad as model space/ paper space. I add what ever I need to add into model or paper space and save the file. When I try to import that file back into Revit nothing shows up.
One of my questions is when I import the .dwg back into Revit should I import it into a sheet or for example a floor plan?
Should I do my work in paper space or model space?
If my scale of the Revit sheet that I export is 1/4"=1'-0" when I import the .dwg back into Revit if anything shows up at all it's too large, even though I'm using 1/4"=1'-0" in ACAD.
admin
I would export to dwg from a view not a sheet, make your changes in model space, and import into views, not sheets. That should take care of the scale issue. You might check your crop region settings if you don't see anything when you import as well.
Hiroshi Jacobs
Firm is switching to Revit; Shop dwgs. |
Sun, Dec 30, 2007 at 2:35:18 PM
Importing .dwg details |
Wed, Jul 12, 2006 at 12:23:47 PM
Imported DWGs not exploding? |
Tue, Feb 8, 2005 at 9:11:31 PM
3D rotation/ Importing DWGs into section |
Tue, May 3, 2005 at 7:45:27 PM
Rev 2009 Importing Structural Dwgs into Arch dwg |
Mon, Jul 25, 2011 at 7:39:15 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
