34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Turn off a category in multiple views - efficiently
Thu, Jan 8, 2009 at 2:05:25 PM | Turn off a category in multiple views - efficiently
JodieAnttila
I have my interior elevation sheets layed out and need to turn the furniture off/on depending on the purpose (furniture off for the main CD's, but on for the FF&E). I know in AutoCAD I could simply turn the layer off; does is there a way to quickly turn the furntiure off for all interior elevation views? I know how to use VG to turn it of view by view (soo tedious). Thanks for the help.
Thu, Jan 8, 2009 at 2:27:15 PM | Turn off a category in multiple views - efficiently
tim123
4 Stars: 19 Votes
Create a view template for each condition - you can then apply these to multiple views.
Thu, Jan 8, 2009 at 2:27:44 PM | Turn off a category in multiple views - efficiently
coreed
coreed Avatar
4 Stars: 16 Votes
you could use a view template, select all views in the broswer that you want it apllied to, right-click and apply the template
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jan 8, 2009 at 2:48:24 PM | Turn off a category in multiple views - efficiently
JodieAnttila
Wow - it worked perfectly, thank you to you both! You saved us a lot of time and frustration.
Thu, Jan 8, 2009 at 2:50:35 PM | Turn off a category in multiple views - efficiently
I would take this one step furthur than what coreed says.  After you right click on the single or multiple views, assign the template you want to these views.
Do this with all your views (other than special single type of views) so that when you need to print, you can multiple select all the sheets in your project and choose "apply default view template". Then all of your vies will be correct for printing no matter who may have been working on them.  Any view not assigned a view template will not be affected by this.
Thu, Jan 8, 2009 at 3:01:28 PM | Turn off a category in multiple views - efficiently
JodieAnttila
I see the choice to "Apply Default View Template to All Views", however, I do not know how to set the default view template. This is a great tip, and I would appreciate the steps on how to set it.
Thu, Jan 8, 2009 at 3:05:00 PM | Turn off a category in multiple views - efficiently
Do what I said .... select your views - then right click and under properties you will find the parameter "default view template" ... when you click on that, there will be a pull down on the right where you can select the template you want to assign
Design Options - Efficiently Changing Option Visibility in Multiple Views
Wed, Nov 29, 2006 at 11:26:42 AM
how visibility of filter work with the turn on/off of certain category?
Thu, Jan 13, 2011 at 4:03:49 PM
Exporting multiple 3D views
Mon, Jul 15, 2013 at 9:08:23 PM
Change a mass category
Thu, Oct 4, 2007 at 10:47:02 AM
Using Region (hatch) in Multiple Views
Wed, Mar 14, 2012 at 8:41:06 AM
Page generation time: 1.9898
