142 Users Online (140 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Grid line as centerline?
Thu, Jan 8, 2009 at 12:58:47 PM | Grid line as centerline?
ChopperDave
Is there any way to get grid lines to count as center lines for the purpose of dimensions. We need the centerline tick mark to show up for grid lines as well as walls and the like.
Mon, Jan 19, 2009 at 9:45:57 PM | Grid line as centerline?
emgeeo
3.5 Stars: 7 Votes
There is, but it's not perfect.  By that I mean- I don't believe there is a way to control each witness line independently.<--Spelling?
At any rate, you'll need to make a copy of your dimension style, and modify the type parameters.  There is a 'Centerline Pattern' option.
OK.  Step by step.
1.  Select any dimension string.
2.  Go the the element properties dialogue box.
3.  Click 'Edit/New'
4.  Click 'Duplicate'
5.  Give a unique name- something like 'Dimension - Centerline'
6.  Change 'Centerline Pattern' to the linestyle you fancy.
You may need to create your own line style under the Settings menu.  Let me know if you need help with this.
As always, let me know if this did or did not work.
Mon, Jan 19, 2009 at 9:47:23 PM | Grid line as centerline?
emgeeo
3.5 Stars: 7 Votes
Wait, you want your grilines to display as centerlines?  Not your dimensions?  Well, it's pretty much the same as I just described- except you will not have to make a duplicate.  Make sense?
Grid Lines at Face of Steel, Not Centerline
Thu, Mar 19, 2015 at 3:16:30 PM
Revit 2016 - highlighting core centerline
Mon, Nov 9, 2015 at 8:10:02 AM
Curved/Arc Grid Line - NOT DASHED
Thu, Oct 13, 2011 at 11:22:19 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
dimension to centerline of mullion
Wed, Nov 13, 2013 at 12:19:56 PM
Page generation time: 6.0261
