121 Users Online (119 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> phasing
Thu, Jan 8, 2009 at 11:41:45 AM | phasing
lauren
I am working on an office building where I have several different phases, each with a small amount of demo & new construction.  For construction purposes, I want to create a sheet that shows one plan with all the demo and one plan with all the new construction, regardless of the phase created or demolished.  I can't seem to be able to manipulate the phasing settings to acomplish this.  Does anyone have a trick to doing this?
Mon, Jan 12, 2009 at 11:52:55 AM | phasing
troeakwj
There may be some work arounds out there but the best approach is to have phases in which demo occurs and new construction occurs.
 Creatre a phase for demo with all of your demo there. Then in the view properties set the visibility to show demo and the phase to new construction.
The new construction view will have visibilit set to previous and new.
In my experiance with many phased projects the more complicated that you make it the longer you will take to finish the project.
Phasing - Building Already Done but Dind't Set up Phasing
Tue, Dec 15, 2009 at 7:40:43 AM
phasing
Tue, Oct 23, 2012 at 8:20:22 AM
Phasing moved to Visibilty/Graphic
Wed, Nov 18, 2009 at 4:11:57 PM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:01 PM
PHASING
Tue, May 20, 2008 at 1:57:26 PM
Page generation time: 0.9848
