89 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Decal
25 Posts No Rating |
Hi am wondering if they is any way of applying a decal to a non flat surface ie a mass face, i am trying to create a hanging curtain type banner, i can create the banner by using solid blend which forms my creases in the curtain and gives it the wavey look i want, is there any way of applying a decal that will follow the curves of the curtain i have made, i suppose i could do it by applying a material but how do i create a material with my poster design on? I hope that makes some sense and someone could help me out. Many thanks
I don't think so, the decal it's a Flat image so use the "material" with the image you want to do that....
I thought that would be the case, therefore what is the best way and how do i go about creating a material using my image. Thanks
In the properties of the object go to the materials and duplicate a "Default" then in "Generic Materials Properties" change the color by image and then select the image you want, adjust ths scale and the others parameters....
Fantastic many thanks
Decal rendering |
Sun, Nov 9, 2008 at 4:02:33 AM
Decal 2009 issue |
Sun, Nov 9, 2008 at 5:29:42 AM
Revit Architecture 2013 - Decal Tool not functioning |
Mon, Jan 13, 2014 at 10:18:31 PM
Decal Placement |
Wed, May 1, 2013 at 7:55:41 AM
decal not working |
Wed, Jan 20, 2010 at 12:30:30 PM
Members: | 2017187 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
