Forums >> Revit Building >> Technical Support >> How do you get the end mullion on a curved storefront to align correctly
7 Posts No Rating |
Hello all - I'm trying to creat a simple curved storefront system. No problem with the interior mullion alignment, but both ends do not behave and are not perpendiclar to the center point of the radius lika all the others. I cannot find a setting or variable to control this - is this a known glitch or am I missing something obvious? I've attached an image (hopefully, this is my first time attaching an image). Thanks.
I don't know any way to do this. If you absolutly have to have it right, you coul cretate a left / right mullion ... beter yet - just have a seperate family that you can place - rotate and stretch to height. Then just don't place your end mullion in the curtainwall.
7 Posts No Rating |
Thanks WWHub, I realized that I had attached the entire building (not just the relavent image), so I've reattached it. I'll try your work around suggestion - how do you not place end mullions in a storefront ? (this was created using the wall type "Curtain Wall: Storefront" right out of the box - I've not modified it at this point).
Select the mullion, un pin and delete. I like to use in place families for my corner and end mullions some times if they are not working how i want them to.
A word of caution ... with automatic storefronts, REVIT will try to put gridlines and mullions back in if you delete/move/change them. Change you wall to a new type after you have created it ... one that has all of the spacings / muillons not set to anything... then delete the end mullions.
Surface hatch for roof with curved end |
Sun, Jan 24, 2010 at 7:26:35 PM
Storefront mullion malfunction |
Fri, Feb 10, 2006 at 10:20:56 AM
mullion join at angled mullion 2017 |
Sat, Oct 21, 2017 at 11:53:55 AM
Storefront will not attached to my wall |
Fri, Mar 4, 2005 at 11:32:20 AM
mullion ang transom not fitting well [ 1 2 ] |
Wed, Oct 9, 2013 at 11:42:11 PM
23
Members: | 2101656 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
