55 Users Online (54 Members):
Forums >> Revit Systems >> Technical Support >> File will not go away. .
3 Posts No Rating |
So, i recently downloaded a file from here for Adjustable Doors (doors with a 45 degree swing). I downloaded the file to my desktop before i moved it to its new home in the "Doors" folder. My issue is this, the file was copied to the "doors" folder from the desktop. . Now the desktop file cannot be deleted. . . WHY? I am currently running Vista. Can that be the crux? I have dragged the file from the desktop to the recycle bin, and it hangs the computer up. I have tried to change the extension to then delete it. NOTHING. . It does not allow this and goes back to the revit extension. So, i have a revit door on my desktop that cannot be removed. . what can i do?? Anyone else face this?? I am open to anything. .
89civicracer, I´ve experimented the same problem. I have windows Vista and that issue only happens with .rfa files in my computer....The only thing you can do is to download the "Unlocker 1.8.7." to delete it. Hope it helps you.
Shared Parameter File Deleted |
Mon, May 19, 2014 at 11:30:31 AM
how to convert a template to project file in 2012 |
Fri, Aug 2, 2013 at 2:58:22 AM
Model file vs. Sheet file |
Sun, Nov 9, 2014 at 4:54:45 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file |
Sat, Jul 7, 2012 at 3:38:16 PM
Importing a cad file |
Fri, Apr 27, 2012 at 3:33:21 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
