72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Detail Component line weights
Wed, Jan 7, 2009 at 12:15:05 PM | Detail Component line weights
apidge17
How do I get heavier lines in a detail component?  The only choices for lines that I have currently are Detail Items, <invisible>, hidden, heavy, light, and medium.  I need a line that is heavier than the 'Heavy' Line.  However, I can not access line styles to make a new line type.
Wed, Jan 7, 2009 at 12:21:35 PM | Detail Component line weights
ChopperDave
It should be under object styles.
Wed, Jan 7, 2009 at 12:36:58 PM | Detail Component line weights
apidge17
OH!  They're considered objects!  I see now!  Thanks!!
Wed, Jan 7, 2009 at 3:17:54 PM | Detail Component line weights
Edit the component family and there you can add additional category lines ... ie SUPER HEAVY ....
Wed, Jan 7, 2009 at 3:53:15 PM | Detail Component line weights
apidge17
where/how do I add category lines?
Wed, Jan 7, 2009 at 4:05:46 PM | Detail Component line weights
ChopperDave
If you mean you want to add new line catagories to the list, just click new under "modify subcatagories."
Wed, Jan 7, 2009 at 4:11:12 PM | Detail Component line weights
apidge17
yea, I just realized what you meant and figured it out.  Thanks for your help!
Wed, Jan 7, 2009 at 4:44:10 PM | Detail Component line weights
The object style has to be added in the family - not project.  It will come in when you re-load the family
Detail Lines Follow Model Line Weights Problem
Fri, Sep 9, 2011 at 9:55:52 AM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:39 AM
Line Weights of Detail Components
Fri, Jul 7, 2006 at 9:02:07 AM
Line Weights not showing in View
Tue, Jul 8, 2014 at 12:45:19 PM
Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:30:54 PM
Page generation time: 2.3952
