54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Editing the profile of a railing
Fri, May 27, 2005 at 4:04:28 AM | Editing the profile of a railing
Huxerama
I want to extend a railing that is attached at the base to stairs to the height of the roof to create a screen. I have made the railing the right height, but because the stairs and the roof are at different angles the railing is higher than the roof at the top of the stairs. Is there a way to fix this? -
Mon, May 30, 2005 at 9:16:07 PM | RE: Editing the profile of a railing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hux, you couldn't do this using a railing as they cannot be cut. you would need to do a family either in-place or externally to achieve what you want. Cheers.
Fri, Jun 3, 2005 at 11:26:26 PM | RE: Editing the profile of a railing
Huxerama
I was hoping you wouldn't say that!
wall railing for ramp
Wed, Dec 18, 2013 at 1:52:56 PM
railing profile in project - not available in edit rails
Fri, Sep 21, 2007 at 11:50:53 AM
help...Wood plank railing gaps
Wed, Aug 17, 2011 at 10:12:06 PM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:42 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:21 PM
Page generation time: 1.0322
