42 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Tittleblock crop boundaries?
38 Posts No Rating |
Revit Architecture 2009 I would like to use two different tittleblocks one large tittleblock and then smaller 8.5"x11" tittleblocks for each of the details on the larger sheet. I have placed 2 titleblocks on a sheet. Is there a way to crop view everything outside of the small titleblock so when I print the larger block and other images won't appear? Ie. Is there a way to set a title block to show only what is inside the block boundry lines? Thanks
You are trying to use Revit like AutoCAD... Not a good idea. You should only ever have one titleblock per sheet view. If you require the same views on different size titleblocks with different layouts then I suggest you duplicate the view as a dependent or simply print the same view at half scale if appropriate...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Thanks Mr. Spot, I hope I am not trying to work like Autocad since I loath the program, but the firm wants to keep it similar to the old style with small size reissued addendum details pulled off the sheets. The duplicate with dpendent does work but it creates more files on the list. I did come up with a solution is very simple. Create a white masking fill region inset of your tittle block family as a border. Make addendum changes in the parent view. Go to sheet and overlay titleblock and print to TTB view at 100% to PDF and create your digital file of changes made in addendum. Not sure if this is the best way, but it doesn't create any new views or sheets and the parent view with clouds will remain for the conformed set. Thanks
Look at this discussion on AUGI http://forums.augi.com/showthread.php?t=53492 Load the family that is there. You can place this 8.5x11 sketch over your normal sheet and it will mask the rest of the sheet.
I downloaded the family but not sure how to get it on the sheet. What command do I use to place it over the sheet? Thanks again
Drag it from your browser and drop on the sheet or just select create instance
Edited on: Wed, Jan 7, 2009 at 3:30:43 PM
GENIUS! I love it. Thanks so much
Annotation Crop boundary is not visible |
Mon, Sep 24, 2012 at 3:16:13 PM
elevation crop boundaries |
Fri, Jun 6, 2008 at 5:08:18 PM
crop region - elevations |
Fri, Oct 23, 2009 at 12:43:33 PM
Dependent view doesn't crop call out area |
Fri, Aug 19, 2011 at 2:24:48 AM
break option in wall section |
Tue, Feb 23, 2010 at 10:14:12 AM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
