Forums >> Revit Building >> Technical Support >> Rendered brick different than brick jpg.
3 Posts No Rating |
Please let me know if anyone has found a good way of getting Revit to render a material closer to the original .jpg than what I am coming up with. I choose a brick and it is just not looking like the .jpg Is this an error on my part somewhere. I have tried changing the brightness of the material and also have messed with the exposure settings, but am just not getting as close as I would like? Anyone have some ideas? I have attached the .jpg image and the rendering so you can see what I am talking about with the brick. Thanks, Matt
You only attached the Render image not the Jpg of the brick...
3 Posts No Rating |
Sorry about that....I thought I had both. Hope it comes through this time.
3 Posts No Rating |
Sorry the one I was tring to attach was to big. This one should work.
Well, i just copy your jpg and apply to the wall with Generic and bump, render in "Medium" like you can see in the image attached, you can allways "adjust Exposure" and try to correct a little bit the image if you want...
brick arched lintol |
Tue, Jul 25, 2006 at 4:55:54 AM
brick pattern not consistent |
Wed, Mar 16, 2011 at 1:22:14 PM
RA-08 Rendered Brick pattern looks like a sphere. |
Fri, Oct 3, 2008 at 5:06:10 PM
Ext brick stairs |
Sat, Mar 19, 2016 at 10:45:23 AM
Adjust Brick veener to move down agianst the brick ledge. |
Thu, Jul 26, 2018 at 2:23:13 PM
Members: | 2118822 | Objects: | 23205 | Forum Posts: | 152310 | Job Listings: | 3 |
