31 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> visibility parameter
Mon, Jan 5, 2009 at 2:53:54 PM | visibility parameter
bert
Hello all,
I'd like to add a grid to our titleblock, to be controlled by a visibility parameter. I had tried out this technique in a generic family and it worked great. Now that I'm trying to do the same in the titleblock family, I can't create the shared parameter I would need (option is grayed out).
How do I get this to work? It seemed so simple before, and now I'm not getting it done.
Are invisible lines another option?
Thanks!!!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Mon, Jan 5, 2009 at 4:00:14 PM | visibility parameter
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You really shouldn't need a shared parameter for this as you use shared parameters mainly for scheduling or parameters that repeat themselves in multiple families like height, length, etc.
A family parameter will work for this w/ o having to add it to the project.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Jan 5, 2009 at 5:31:27 PM | visibility parameter
bert
that's true, but I'd like to schedule it. Actually, I don't want to see the grid being printed, and scheduling the visibility would allow me to quickly check whether or not all sheets have the grid turned off. (I use a working schedule with all the information that's available on sheets).
I had tried out invisible lines, but those became invisible (seems logical) so they were of no use to me in lining up my detail views.
using RAC-2013
Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
Wed, Mar 7, 2012 at 5:53:47 PM
Dimension parameter based on visibility
Tue, Sep 22, 2009 at 3:43:00 PM
EXTRUSION YES/NO PARAMETER
Mon, Apr 28, 2014 at 4:04:37 PM
11
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:10 PM
Using a Yes/No Parameter to control the visibility of another Label in a Tag
Wed, Feb 6, 2013 at 2:03:22 PM
Page generation time: 0.9741
