60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Import AutoCAD or SKP to Revit as 3D masses for light renderings
Mon, Jan 5, 2009 at 1:08:44 PM | Import AutoCAD or SKP to Revit as 3D masses for light renderings
iREV
3.5 Stars: 3 Votes
I am trying to import a complex 3D file from AutoCAD into Revit.  The file will import from AutoCAD as a 3D block but when I try to show shadows it does not show any.  When it is exploded it converts to 2D only.  When imported in to SKP then RVT it does not work.  What I am trying to do is create a Revit file that I am able to use .ies photometeric web files to show a basic 3D rendered model of how the lights will reflect off of the geometery. Does anyone have any suggestions on how to make this work?
Mon, Jan 5, 2009 at 6:33:10 PM | Import AutoCAD or SKP to Revit as 3D masses for light renderings
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Have you tried creating a mass and importing the skp file into the mass?
In the past I have used many sketchup and 3d cad files and have never had this problem..... I think.
import revit renderings into autocad
Mon, Jan 17, 2011 at 2:18:17 PM
Another newby migrating from AutoCAD & Sketchup to the wonderful world of Revit!
Fri, Nov 19, 2010 at 4:05:16 AM
Bringing an SKP file into RAC 2011
Mon, Jul 8, 2013 at 1:41:20 AM
Can't import SKP file!
Sun, Feb 8, 2009 at 3:58:59 PM
Downlight with hidden light source
Sat, Nov 23, 2013 at 8:19:33 AM
Page generation time: 2.0232
