73 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Multiple users
5 Posts No Rating |
Is there any way mulitple users can work on the same file and save the changes made into the same file?
Most definitely.
I suggest you investigate worksets. It may also be an idea to get some formal training using them. But basically you enable worksets by picking the worksets button (once done this cannot be undone)
You set what workset you want all the model elements already created to belong to. And another for levels, grids etc.
The first save is the central file. This should be placed in a location where everyone has access.
You then do a save as to save a local copy (avoid working directly into the central file). you then work in this file any work you do can be saved back to the central file which will also keep your work up to date.
How you setup your worksets and how you use them, borrowing as opposed to making the workset editable is something that must be planned before hand. And as such i suggest you sit down face to face with the appropriate person with the experience on how best to setup your worksets and use them.
Also checkout the tutorials in revit.
HTH.
Multiple User Worksets |
Wed, May 14, 2008 at 1:42:54 PM
Revit 2013 - File Structure Standards Multiple Users |
Mon, Mar 4, 2013 at 12:09:14 PM
Multiple Users within a Project |
Tue, Oct 10, 2006 at 10:48:31 AM
Multiple Users creating Sheets in Local Fiels?!? |
Thu, Jun 7, 2007 at 4:20:56 AM
Multiple Users and Worksets |
Fri, Jan 15, 2010 at 7:00:34 PM
Members: | 2017442 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
