Forums >> Revit Systems >> Technical Support >> Add ''scale'' on a drawing list, when it is not under ''available fiel
9 Posts No Rating |
hi, is there anyone knows how can I add ''scale'' column to my Drawing List? ''Scale'' item is not showing under Fields- Available fields, as showing on the attached picture. But I have '' scale'' on my sheet. anyone can help me? thanks a lot!!
You are scheduling sheets. The scale on a sheet is dependant on the views on the sheet. If you have 1 or more views and they all have the same scalle then it will read out at that scale. If they are different scales then it will fill out at "As indicated." If you want a view list goView-New-View List. That will list out all of your floor plan, ceiling plans, etc in a list and scale will be an available field. It wil probably not read out as you expect though. Revit calculates the scale out in base numbers and the 1= is implied. So a 1/8" = 1' drawing will have a scale of 96.... HTHNick
I would just create a generic text parameter for this and then just type in the scale. Since it's text it will keep the values that you type in so you will be able to change them through the pull down in each cell...or just copy / paste. Like Nick says, the list is scheduling sheets and the scale is dependant on the view. You can't creat an inteligent parameter to read the scale of a view and list it in a schedule for a sheet. HTH
9 Posts No Rating |
Hi, guys, it was very helpful!! thx a lot again. & have a nice day!
I simply don't understand why Revit knows how to calculate the scale on a sheet but doesn't know how to do this in list of sheets?? In most cases I use the same scale in one sheet and so i get one scale like 1:50, 1:100 or so. And even if there were differents scales, I don't mind "As indicated". So why there is no column "scale" in sheets' list? It's not logical.
The solution to do this manually is not suitable for me although I use this often because of missing interconnections between elements (like height of a room or others).
So maybe in a newer version? I use Revit 2011 and there is a little expectation of upgrade by my company.
Nessie
Revit 2013 |
Drawing List's |
Wed, May 26, 2010 at 11:49:43 AM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:47 AM
How to scale 2D 'scalie' figures (.rfa) in Revit '08. |
Sat, Feb 2, 2008 at 9:57:09 AM
'Out of Memory' pop up |
Tue, Sep 6, 2005 at 3:16:08 PM
When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e |
Fri, Jun 11, 2021 at 7:44:54 AM
Members: | 2098828 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
