54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dividing a 2d line
Thu, May 26, 2005 at 3:20:35 AM | Dividing a 2d line
Boarch
I`m just wondring about if there is a comand in Revit 7 that divide a 2d line in several parts in same size. In AutoCad there is a comand called "divide". I`m new in Revit, so maby the question is not so clever... ;Winking Hope someone can help me. Thanks, Stian Post edited on 2005-05-26 03:28:11
Thu, May 26, 2005 at 11:00:52 AM | RE: Dividing a 2d line
TomDorner
4.5 Stars: 25 Votes
In Revit you can use dimensions to control equality. You could set up reference planes for instance, add a dimension string to them, then click on the little blue "eq" control and then they will all be equally spaced. Since this equality is maintained even if the outside lines move, it is vastly more powerful than the ACAD divide command. Revit is all about levels, grids and alignments use them to your advantage. HTH Tom
Dividing a line
Tue, Sep 4, 2007 at 9:06:00 PM
dividing project and linking files : structure, interior/envelope walls
Wed, Apr 6, 2005 at 6:22:48 PM
Line weights for hatch?
Mon, Mar 23, 2009 at 2:24:48 AM
No dividing lines on sections ?
Sat, Mar 14, 2009 at 2:39:37 PM
Help dividing surface of imported .sat file to create curtain system
Sat, Nov 13, 2010 at 12:44:51 PM
Page generation time: 0.5933
